Montag, 6. August 2007, 12:10
Kenworth heavy + tank trailer
And it's time for a next model.
Tihs time it is a Kenworth from Revell, heavy hauler. Pretty rare and expensive model, old at least ten years.
The truck will cut and extended, one more steer axle will be added, a crane kit from KFS will be added, with a seat and everything. An extra axle came from Zipi ( :prost: ), and front wheels will be reaplaced with KFS TQ20B wheels.
Next thing is a 3axle dolly, which is going to be made from a 6-axle heavy tank trailer from Revell.
And then comes a trailer. 6-axle flat bed trailer from Revell. It will be cut, turned to extendable, and expected to be 82 cm long when extended.
And on the trailer comes a load. It will be a train car.
The all together length will be huge, also a lot of work will be involved, and a lot of money has allready been spent on this porject. :bang:
Bauberichte=>Kenworth heavy + tank trailer
Bildergalerie=>Revell Peterbilt Alaskan Hauler + Heavy Gravel Trailer
Bildergalerie=>Revell Bussing + Hanomag trailer
Dioramenbau=>Display case for trucks in 1/24
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »VW freak« (13. August 2007, 19:07)
Montag, 6. August 2007, 16:39
Hello Matjaz,
I think you want to build a beutiful truck, Revells Kenwoth heavy is ja nice Truck with Bullbar, a lot of weels and so on. This Trailer ist perfekt for the Truck, you can't find anythink thats better for a Heavy Truck.
:wink: Marco
Montag, 6. August 2007, 18:47
Hi Matjaz!
thats a really great project :ok: - i can´t wait to see the finished Modell!
The Kenworth is a very interesting Truck- i sterted to built it too- but mine is the newest generation by revell.
Where did you get the truck and the trailer- ebay? :nixweis:
Greets, Thomas :wink:
Grüße, Thomas :wink:
Und nicht vergessen: :schrei:US-Trucks forever!
Montag, 6. August 2007, 20:15
Thank you for your wishes.
Yes, all modells used in this composition ( Keny, both trailers and a railroad car ) were bought on e-bay.de.
Dienstag, 7. August 2007, 19:02
@ Matjaz:
:hand: Thanks for the answer!!!
Dienstag, 7. August 2007, 19:45
Hello Matjaz,
Good luck whit this big project. I will follow your buildingproces. When do you think it will be finished?
Greatz,
Egbert
Dienstag, 7. August 2007, 21:50
If all goes well, in about 1,5 or 2 years :rot:.
I'll take the time and work slowly, because I want to make as good as I can.
Realname: Andreas
Mittwoch, 8. August 2007, 17:19
Hy Matjaz,
looks to become a very interesting and really HUGE projekt. :) :ok:
So, what can I say except:
"Have a nice trip, boy!!" :)
I will take a look at your posting every time I`ll come to this site.
Wish you lot`s (and ton`s ;) ) of fun and naturally good luck!
Greetz, A.
Freitag, 10. August 2007, 19:59
Thank you.
And on we go. The undercareage is finally put together. At least the length. :cracy: It's made from 5 pieces. Blue part, two times black part, another and white part. The legth is allready 42 cm.
Sonntag, 12. August 2007, 10:04
And again some progress. The undercareage is finished. It is now straight, in line and glued together.
Montag, 13. August 2007, 19:12
And I have to notice you, that there has been some changes. :rot:
I found some really good pictures, and then also Zipi hepled me to decide to make a different model.
And, there will be no flat bed trailer and no dolly :will: :will:
And also no train car :idee: :idee:
There will be just a 6 axle heavy tank trailer from Revell.
The only thing that stays the same, is the truck, and it will be much more modified than originally thought. :verrückt: :verrückt:
And some pictures of the truck that inspired me for this idea.
:ok: :ok:
raceroland
Samstag, 18. August 2007, 23:42
Hello Matjaz
What in heavens name is this??????????? it´s a real bombastic roadtrain,also the choice of color is beautyfull not the white / black or red ones we see all the time. :ok:
PERFECT RESULT :hand:
Roland
Sonntag, 19. August 2007, 08:16
Thank you.
But I have to admit, that this truck isn't my work. :rot: :rot: I found those pictures on the internet. There are also some others very beutifull and amazing ideas about trucks. :cracy: :cracy:
3D art pool
And finally the undercareage is ready for painting. Pictures will be followed soon.
And now I'll start working on the trailer.
:wink: :wink:
Samstag, 1. September 2007, 20:58
Hi.
I'm asking you all to help me, please.
Could you please give me some ideas about the colour of the main frame ( undercareage ) and for the motor. The truck will be painted like on pictures above in purple with chrome.
Thank you for your ideas.
Realname: Pascal
Montag, 3. September 2007, 05:35
Hallo Matjaz,
Could you send me a detailed picture of the manual where the bullbar is mounted on the truck??
I saw a picture on the box but that picture isn't quite detailed.
With kind regards,
Pascal
Realname: Pascal
Montag, 3. September 2007, 05:43
Hallo Matjaz,
Perhaps you should paint the undercareage in silver or so.
I think its a good combination with the purple paint.
And:
if you don't use the flatbet trailer, is it for sale?? if not, can the load(big engine) be bought??
MFg Pascal
Donnerstag, 6. September 2007, 14:47
@ Silencer: The picture is coming. Sorry, but neither flat bed or the cargo are not for sale. They will be used in nekt project. :rot:
Thank you for your advices. The finall color of the frame will be decided today. It will be green, I just don't know yet how light and how intense green.
The main frame is mostly done and customized ( main frame, axles, universal joints,... )
Then I had to do a new cabin holder on the back side.
PE meshes for exhaust pipes are ready.
And first tests of rolling them have began. But I came to an obsticle. I don't know how to roll them without snaping them along the holes. If I do it by the instructions that the PE parts came with, I can roll them, but I don't know how to make them stay rolled. Finall diameter should have been around 12mm, but when I let them go, They unroll back to about 20mm of diamater :motz: :motz:
Now I rolled them on a 11,5mm tube, and permanently fixed in that position, so they cannot unroll. I'll let in this way for about 2-3 weeks and hope, that they wiil stay rolled, when I peel off the tape.
If someone has done this before, PLEASE HELP!!! :nixweis: :nixweis:
Silencer:
Sorry, but in instructions it also doesn't say where excatly is the mesh :motz: :motz:
Picture of the manual
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »VW freak« (6. September 2007, 14:50)
Realname: Pascal
Donnerstag, 6. September 2007, 15:33
Hi Matjaz,
Thanx for the picture. It is in fact quite helpful.
With the exhaust pipes i can't help you, I have no experience in that.
Good luck with the project,
Pascal
Freitag, 7. September 2007, 08:07
Hi Matjaz.
You are building a very nice truck:ok: , I can`t wait to see it ready!
I don`t think that the exhaust meshes will stay at 12mm after 3 weeks, becaus it is metal and they will always turn back a little.
Maybe you should roll the meshes on a diameter smaller than 12mm, so if they unroll their diameter will be approximately 12, then you can fix it with the pe rings.
I hope it works.
Greetings from Austria:wink:
Freitag, 7. September 2007, 09:57
Thank you, but the problem is, that I've allready tryed to roll them to a 10 mm, but one mesh started cracking between the holes :motz: :motz:.
So now I'v decieded to let them rolled as they are, on a 11,5mm, then I'm gonna super glue them together.
Hope it works. I can't bend no more. If I bend them some more, I'm affraid I'll have to buy a new set.
Freitag, 7. September 2007, 21:54
:tanz: :tanz: :party: :party: Yesterday I got another ( this one has allready been built, but when comparing the prize I payed against a 120€ for a new one, so I'll just make 1 out of 2 allready built ) Heavy tank trailer.Thank you Skandinavc FH :ok: :ok:.
And now let the games begin :lol:. The truck is on a pauze ( I still managed to make a new cab holder, new exhaust pipe holders, built the engine to the point, when it is ready for the painting... ) because of lack of will :rot: :rot:. But another trailer returned the will so tomorrow I'll "unpaint" them and make them ready for a new paint, and with a bit of luck, perhaps also cut them both if enough time remains.
Pictures will follow.
:wink: :wink:
Samstag, 22. September 2007, 12:38
And again some more progress.
Both trailers that are going to be used in this project.
First I cut out the holders on both sides.
And after a lot of messaureing, thinking, drawing,.... sawing of the undercareafe and of the tubes began.
Some testing pictures of the truck and trailer.
But, the length wasn't good ( the trailer was simply unreal long ), so I started cutting again and last night me and ZiPi came to a super idea. And on with the cutting we go :lol:. Here is now the body of the truck. It has to be shortened one more time, because it is still too long.
And the body for the trailer.
And a new placement for the trailer. It will now have only 6 axles, bu it will be lengthened.
That's all for now. Oh. The truck will have 2 axles with super single wheels that will be followed by 3+2+6 axles with 4 wheels/axle. :verrückt: :verrückt: :verrückt:
Dienstag, 25. September 2007, 18:21
The body for the truck is glued, edges have been paper-sanded off.
And today I had to cut off from 0 to 1,5mm of the underbody, to level it to total flat, because originaly it was made for a seadle and some other stuff.
And first tests with new profiles for the body, and the underbody is now ready for painting.
Donnerstag, 22. November 2007, 16:21
Uf....
It's been some time, since any progress :( .
Well, now I began making some progress on this truck, because it has to be finished before the birth of my son.
I first tryed to coat them in polystyrol plates, the I've put too much glue, and the result was all sprincled :pfeif:. You can see it on next piscture, so I had to throw them away.
Than I bought a drainage pipe, cut it in 2 pieces.
Then I andpapered it with 400, then 800, and with 1200, and the result is allready something I like. Why sanding if it will be sprayed? For more shiny colors.
Any comments?
Donnerstag, 22. November 2007, 19:57
wow, what a great project .... i´m very impressed, i cant believe it :respekt:
MfG
Kersten
Im Bau: Jeep Golden Eagle 1:16
Realname: Pascal
Donnerstag, 29. November 2007, 03:38
Hello Matjaz,
Your truck looks very great, keep up the good work.
Ist there any progress??
MFG Pascal
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Silencer« (29. November 2007, 03:38)
Donnerstag, 29. November 2007, 10:10
I hope I will be able to continue soon, because a week ago, I was makeing some progress, but then, when I was cutting off some plastic, one piece of it flew into my eye and got stuck there, so I had to ask my wife in the middle of the night, to take me to the hospital. I'm still recovering, but soon, I hope it will go on.
Realname: Pascal
Donnerstag, 29. November 2007, 12:24
Hello Matjaz,
That's not verry good, who says modell building is a safe hobby...
But i wish you a fast and good recovery from your injuries :trost: :trost:.
With kind regards,
Pascal
Donnerstag, 29. November 2007, 20:23
And on we go. My eye is now OK, so I returned to work.
I inserted plastic caps from heavy tank trailers ( the only think that could have been saved ). Then I added some car cit, and left to dry.The car kit "grabbed" both sides, plastic and metal, amazingly strong..
And today I've used some sand paper ( 40, 80, 180, 800 and 1000 ) and the result was super. I also find out, that maybe I won't have to color the pipes, if I sand them very well :idee:.
Any comments?
Dienstag, 22. Januar 2008, 21:20
After a long time, some more progress can be seen, now that the exams are over, and a new desire for model building is here :lol:.
The trailer undercareage has been put together in one piece. All axles were broken off, so I had to bore holes and make the trailer ready for instalation of metal axels.
And some wireing has been done.
