Mittwoch, 28. Oktober 2009, 13:43
Hello Anthony !
Very, very great work.
I´m sure, that the model finally looks like a real helicopter with all details.
Regards
Thorsten
Mittwoch, 28. Oktober 2009, 20:43
Thank you very much Thorsten, much appreciated.
I am hoping it looks like the real helicopter too!
Cheers
Anthony
Samstag, 28. November 2009, 05:28
Hi again gents, well time for a much needed update.
I have been away from home quite a lot again. Seems like I am away more than at home sometimes!
However all is not bad......................I have been doing some research on my next project!!!
And this second photo is the actual machine I will be doing
Anyway.....must not digress, this is my BK thread
Now I am home again, I have been working on the skids like Oliver. This has proved quite a tough task and this is my 3rd attempt.
First I marked out the skid width at the centres as well as the height of the belly at the cross tube point from measurements taken off the actual machine. This gave me the "sit" I had to achieve.
I used some old skids I had left over from an EC-135 parts ship and used the much modified legs from the BK kit. These were modified at the base and had cuffs etc added. Then the lengths were cut and an extension piece of tube was glued on so that it protruded into the fuselage and can be anchered down at the correct angle. I cut down the front section of the EC-135 skid to match the BK. Then I have reamed out some tube of the appropiate diameter to slip the skid ends into, thus representing the straps around the skids. These will get more detail added once the main skid structure has been completed.
Anyway I will let the photos explain a little better how it looks so far.
I have also done some work on the rear clambshell doors, but forgot to take a photo. Will try to update tomorrow as I have to go out for tea soon.
Cheers and thanks for dropping by.
Cheers
Anthony
Donnerstag, 10. Dezember 2009, 07:45
Ok ok, here are some photos. Sorry the quality is not so good.
So I had a spare set of EC-135 skids that I thought would do the job after modifying and cutting down to shape as per previous posts.
Well that didnt work well as I just couldnt get the sections to line up perfectly. Eventually I got a piece of 3mm tube and grafted the front section on with a pin and superglue. Yhis was all blended in and then the centreline of the first vertical tube was marked out (from skid tip back = 25mm). A curve was filed out of that and the previous tube I made was jigged and set at the correct angle. Then another curve was cut out 59mm back to the rear tube centre and the rear tube set and glued in my jig. Finally the rear end was cut off 12mm from the rear tube centreline.
The joints were then blended in with Mr Surfacer and all sanded to the correct shape. I then got another section of the skid tube and reamed out the centre to make it wafer thin. I then slit it and slipped it over the skid tube. Being the same diameter it left a small gap with which I put the wee block in that sits on the top of those hose type clips. There is a panel join under the vertical tubes on the lower skid side.
For this I placed a thin strip of plastic card and blended in the top side to the tube join. A step was made with a piece of channel on the bottom with the edges thinned so that it would slot nicely over the skid and ends put on it. Finally a tip was put on the rear of the skid. I have been putting the clips and mounting brackets on for the step mid way up the skids.
Does all this make sence??? Hopefully the pics will explain better
I set it all up on my jig so as to assure I get the correct "sit". The main skid centres are 2.440M or in 32nd = 76.25mm. The height of the belly in line with the rear skid is exactly 10mm and 13.75mm for the front. This will ensure your BK will sit right.......hope those measurements help those of you building one.
And here they are roughly sitting in the fuse................now for port side!
There are still a few details to be worked on still.
As always, thanks for dropping by.
Cheers
Anthony
Donnerstag, 10. Dezember 2009, 16:11
Hello Antony,
great work so far ! :ok:
All the details you build, 99% like the real helicopter, just in scale 1:32 !
Greetz, Til :wink:
Samstag, 16. Januar 2010, 05:20
Thank you for that.
Next up was to again deal with the floor. I almost had it all fitting right, but it needed final tweaking to fit nicely. A front bulkhead was installed with 2 holes to accept the torque pedal tubes on either side. The floor also protrudes past this bulkhead as well, so a piece was measured, glued and faired into the floor. There is a panel that sits on this BK's floor that has the holes cut out for the 6 tie-down points. Now was time to measure up their positions and drill 6 2mm holes in a floor panel I made (4 times no less to get the shapes/ cut outs all in the right places!).
In this photo you can see the floor extension and bulkhead with the holes drilled out.
Next up was the covers for the cyclic and torque pedals etc that are installed on the passengers/spotters side of the cockpit.
There was actually a bit of work in these even though it dosent look like it. Especially the big 'T' shaped one. My drawings and measurements took a lot of head scratching as well (mental note.........make better/ more clearer sketches!). I went back down to see the chopper and spotted a small detail I would have missed as well as a new antenna fit under the belly.....grrrrr.
Anyway here they are made
And here they are installed
Thanks for dropping by
Cheers
Anthony
Samstag, 16. Januar 2010, 05:22
Well, I bet you all thought I had chucked it back in the box to do something else? Been a while since my last update as I have had family over to stay with us from England and Australia. They have all gone now and I spent the last week on the BK.
First off, here are some slightly better (just)pics of the skids, they are both pretty much done now but still need a few small details added like rivets etc
Spent a fair bit of time this week figuring out how to make the rear clambshell doors look better as they are a bit slab like on the edges. I ran a half round across the bottom edge as well as glueing a thin strip of square section card around the edges, but only about a third of the way in (leaving 2/3 inboard). I then sanded and blended it into the door edge and then filed the outside flush. A coat of Mr Surfacer again blends it all in nicely. Now it has a 'lip' around the edges as per the actual ones.
Donnerstag, 6. Mai 2010, 01:30
Well, as you can see above I am getting to grips with my new computer software.........photos are a bit grainy though......
Anyway as you can see in the above shot I have the EC-145 light panel grafted under the nose.
In this lower shot you can see that I have finished all of the door seals on the rear fuse. There is an inner and outer set. This was quite a challenge as I used fine thin strip glued around the edges and then re-glued with very thin CA. This was then flodded again with Mr Surfacer and then the edges filed down to a scale width to match photos. Note also on the lower floor now there is a new piece glued to the bottom. This is the new lower fuse structure and as you can see, the rear of the belly needs to be extended back to correct the profile.
Unfortunately this next photo I took here isnt very good either, but you can see the antenna's fitted forward of the upper engine intake cooling scoops. I initially used the kit ones but they were too square, so I made little plates on the cowl, drilled 2 small holes and inserted a suitably bent piece of fuse wire to the correct shape. I got a bit ratty with it but am happy with the difference it has made.
Next to recieve attention was the main rotorhead and blades ....again!
Now I definately dont like the BK-117 kits rotorhead or blades.....call me fussy, but I have come too far now. The rotor dia is a bit small and the blades are not good enough. I have decided to go with the highly modified EC blades and hub. First off the aerofoil section was changes as the 145 blade is flat on the bottom whereas the BK is not. Then the 'bump' was put in the leading edge near the root and the shape and length was changed as well as tip detail. I also added a new trailing edge and hub attach point details. All in all each blade has about 25 new pieces in it so far..... The hub was improved by adding new ends. there are still qite a few new bits to go on, but I need a break from them for a few days.....they are driving me nuts. As you can see (just)I have started adding the photoetch from the Reniassiance set on the blade roots. Not much to see, but there are star shaped nuts on the other side as well, I have only just started adding these on one blade.
This shows the centre verticle console being made along with the main hub. I couldnt balance it in the model to take the photo as it kept falling over by the time I got back to the camera!
Well, thats where she is now. I have really enjoed getting back into her again.
Cheers and thanks for dropping in
Donnerstag, 6. Mai 2010, 09:30
Hey Anthony,
amazing patience you show along your model. Biggest respect. Looks great again. Canßt wait to see the finished bird
Donnerstag, 6. Mai 2010, 11:13
Thank you Georg!
I have sent you a message through ARC.
Cheers
Anthony
Donnerstag, 6. Mai 2010, 17:45
Check!
In Progress. Thanks mate!
Samstag, 22. Mai 2010, 04:59
Well, small (visual) update.
I have superglued & MEK'd the starboard skid in now. I know it looks easy enough, but in order to get the weighted 'sit' I had to jig the fuselage and then attach the skids at the right angle. I have had to put them on now as they need 'cranking down and superglueing in order to get a strong bond etc.
Well, I dont have the nervous energy to glue the other in just yet (anyway I have a couple of little things to add to that one), and my fingers are encrusted in superglue.
Thanks for looking
Cheers
Anthony
Sonntag, 30. Mai 2010, 01:03
OK here she is....................finally standing on her own feet!
Seems quite nose heave so I 'may' not need nose weight.
Thanks for looking
Cheers
Anthony
Montag, 31. Mai 2010, 22:39
Hello Athony,
I love your work. That's the best BK 117 in this scale on earth :ok: . I would see the BK in real, but you live on another continent :!! :D :D
I will follow your build ;)
Best regards
Patrick :wink: :wink: :wink:
Dienstag, 1. Juni 2010, 10:39
Hi Patrick, great to hear from you again my friend!
Thank you for your kind comment, I appreciate it very much.
You are always welcome to come and visit, there is a spare room here.......... :ok:
Cheers
Anthony
Dienstag, 1. Juni 2010, 13:55
Hello Anthony !
Great, great work.
It look´s really good.
I think, with colour it will be a perfect Helicopter.
What kind of cockpit will you build ?
From the modelkit or the cockpit from cakemixer ?
Regards
Thorsten
Mittwoch, 2. Juni 2010, 11:55
Hi Thorsten
Thank you for the kind comments...................I am enjoying your 135 very much also!!
I will definately be using Chris's (Cakemixer) cockpit and airframe details. His work is just amazing. I look at it most days feeling too scared to start............but I have done a little already!
Thanks again :ok:
Anthony
