Einziges Detail dass ich verbessern würdeSie hat den Kopf etwas zu betrübt gesenkt.
fällts eben vedammt schwer, es wieder runter zu reissen.
Ich meinte damit aber nicht, dass Du das runterreissen sollst.fällts eben vedammt schwer, es wieder runter zu reissen.![]()
Jaja.... zuerst die Destruktion anordnen und dann nicht dazu stehenIch meinte damit aber nicht, dass Du das runterreissen sollst.![]()
Da mein Schiff (im weiteren "mein Diorama") irgendwo zwischen 1830 und 1860 angesiedelt ist, wäre es wohl kein historischer Verhau, meine vier kleinen Oberdeck Langrohre durch Paixhans Haubitzen zu ersetzen...
In 1827 the French navy ordered fifty large guns on the Paixhans model from the arsenals at Ruelle and at Indret near Nantes. The gun chosen, the canon-obusier de 80, was so called because it was of the 22 cm bore diameter which would have fired an 80 pound solid shot. The gun barrel weighed 3600 kg and was the bore was of 223 mm diameter and 2.8 m long, firing a shell weighing 23.12 kg. The guns were produced slowly and were tested afloat through the 1830s. They formed a small part of the armament on larger ships, with two or four guns only being carried, although on smaller, experimental steam vessels they, and the much larger canon-obusier de 150, of 27 cm bore, were proportionately more important, the paddle steamer Météore, for example, carrying three canon-obusier de 80 pieces and six small carronades in 1833. Alongside the large guns which Paixhans had called for, the French navy also used a smaller shell gun, of the same 164 mm bore as its standard solid shot-firing 30 pounder guns and carronades, in larger numbers with first rate ships carrying over 30 of these guns.
3 Besucher
1800er, 1850er, 1:150, 3rd rate, 74, Conversion, Heller, Krimkrieg, Linienschiff, Segelschiff, Ship of the Line, Superbe, Umbau
