Hello !
Here I am testing with super single front tyre.
I decided to use such front tyres but I also decided to exchange the front axle to the one from the US Heavy Dump truck model. When fitting the front axle I also put distances between the axle and the chassis so the front end would be higher.
Regarding the front rims I wanted to have longer and bigger wheel bolts. I decided to create these all by myself instead of buying from example KFS in order to save some money. Here you can see how I did.
First the original front rim.
Here are the modified ones.
Here is the result after painting. As “wheel bolts” I used short sections of the pin from an ordinary cotton stick for your ears (Topz)
Here is a test assembly but still with the original front axle.
More will follow soon.
Best regards
Håkan
