 , ich bin davon ausgegangen daß die Geschütze während der Fahrt ganz hinter den Pforten stehen
 , ich bin davon ausgegangen daß die Geschütze während der Fahrt ganz hinter den Pforten stehen								Klingt für mich auch logischer, weil ja sonst durch die Gischt das Rohr feucht werden kann, was bei Feuerbetrieb nicht ganz so dolle wäre. Aber ich muss auch sagen, ich habe keine Ahnung von der alten Sehfahrt...Dann ist alles klar, ich bin davon ausgegangen daß die Geschütze während der Fahrt ganz hinter den Pforten stehen
 So konnte die Gefechtsbereitschaft sehr rasch hergestellt werden, da auch das Geschütz schon in vorderster schussbereiter Position stand.
								Soweit jetzt alles klar, nur warum der ganze Aufwand mit den Halbpforten? Um auf dem kleinen Schiff mehr Deckfläche freizuhalten?
"When an enemy was in sight, the crew was called to quarters, as “battle stations” were then called .... In a quick scramble of disciplined activity, everything not needed for battle was struck belowdecks. The galley fire was put out; furniture in the captain’s and commodore’s cabins was moved belowdecks to make room for the gun crews. ...
The gun crew first unfastened the lashings which held the gun secure at sea. This had to be done with care. Gun carriages were not fixed to the deck; if ...
The crew now removed the covers that kept dampness out of the bore, and took various gunnery implements from their racks. Guns of this period were equipped with firing locks, ...
Down below the frigate’s waterline, the gunner and his assistants opened the forward and after magazines and began to break out sausage-shaped flannel powder cartridges for the guns and carronades. Other men took stations along the lower decks to pass cartridges up to the gun crews"
The British Admiralty did not see fit to provide additional powder to captains to train their crews, generally only allowing 1⁄3 of the powder loaded onto the ship to be fired in the first six months of a typical voyage,[citation needed] barring hostile action. Instead of live fire practice, most captains exercised their crews by "running" the guns in and out, performing all the steps associated with firing but without the actual discharge
								die künstlerische Freiheit sei Dir gegönnt
16 Besucher
 Bauberichte »
 Bauberichte » Plastik: Schebecke 1:50 von Heller
											(11. Dezember 2011, 18:49)
										 Bauberichte »
 Bauberichte » Im Bau: Die Schlacht von Wagram 1809
											(17. Mai 2012, 11:22)
										 Segelschiffe »
 Segelschiffe » Holz: Französische Schaluppe 18. Jahrhundert
											(12. Juli 2012, 19:09)
 Samstag,  1. November 2025, 00:36
 Samstag,  1. November 2025, 00:36 Zum Seitenanfang
 Zum SeitenanfangForensoftware: Burning Board®, entwickelt von WoltLab® GmbH
