Freitag, 13. Oktober 2006, 10:46
RENAULT R370
Hi
this was build some years ago, i have used rear part of chassis and chassis parts from heller G260 with some modification on suspension-extra leafs because original was too low ,everything rest is italeri,there is also bigger tank,it was made from two original tanks,and spare wheel carrier comes from turbostar
Freitag, 13. Oktober 2006, 11:32
Very nice Model!!! You just gave me the answer for solving my problem to built a 2axle Renault!!!
It would be nixe to see some Detailphotos of the Renault!!
Greetings
Weil: Elles onder 8 Zylinder isch assozial :P
Freitag, 13. Oktober 2006, 14:53
hi
i have some fotos from building process, but there are before digital cameras era, so i need to scan this, i will upload as soon is possible.
i could say that it wa seasy to match this two parts, heller has sligtly smaller chassis rails, but this give you enough space to build flanges, which are missing on heller kit.
Bastlwastl
Freitag, 13. Oktober 2006, 17:25
Hi borut, :wink:
very very nice truck and trailer. :ok:
i am very impressed from such a great work.
Greetings....
Bernhard
Freitag, 13. Oktober 2006, 22:29
RE: RENAULT R370
Hi there
Always great to see some older trucks being build :ok:
I also have one of these Renault trucks in stock - i´m just still looking for some ideas for it.
Great idea to make a 4x2 out of it, and also putting the older model trailer after it.
Great job - keep up the good work.
Greetings :hand:
Der Däne (Sören)
Donnerstag, 19. Oktober 2006, 15:21
RE: RENAULT R370
hi
thanks for comments
so, as i promised, there is two picture how i have build chassis from two kits
unfortunatly, this are only two pictures that i done this time
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »sviz2000« (19. Oktober 2006, 15:21)
Donnerstag, 19. Oktober 2006, 15:35
Thank you very much for the pictures. Now i can see where i have to cut the two chassis parts.
Thanks again!!
Freitag, 20. Oktober 2006, 19:30
You've exceeded the word quality modeler.
You' re really become one of the best.
I especially like your sense for detailes and for making the model as real as possiblle.
P.S. Sam eno vprašanje: a bomo vidl kdaj te makete na kakem tekmovanju :!!??
Bauberichte=>Kenworth heavy + tank trailer
Bildergalerie=>Revell Peterbilt Alaskan Hauler + Heavy Gravel Trailer
Bildergalerie=>Revell Bussing + Hanomag trailer
Dioramenbau=>Display case for trucks in 1/24
Samstag, 21. Oktober 2006, 22:49
hi
thanks for all comments, i'm very glad that you like it
about cuting, be aware, as you can see, i cut a litle bit too much, and then i need to put some plasticard part between.
this chassis represent 3200 mm wheel distance, as is for older V8 models
about competions, as you VW FREAK already know, i never compete with models, only with real trucks ;)
