  • »Tony70« ist der Autor dieses Themas
Realname: Antonín Velecký
Sonntag, 1. Februar 2015, 18:53
Diesel Air Compressor DK 661 - Small Models (1/87)
Hello.
Here is my next model. It's an old Czech diesel air compressor. Model is from Small Models and it is possible to build two versions.
The civilian version.
The military version.
I chose a civilian version. The compressor will be open, so I cut the upper part.
All inner walls I sanded to be as thin as a sheet.
Before
After
From the aluminum sheet I made a new upper part.
And holders.
I changed the lights. They have a smaller diameter and I used etchings Hauler. I used the original etchings from the kit and I stuck the upper part and holders.
I continue to work on the chassis. The chassis was simple. I have added a mechanism handbrake, cables and a few other details.
I used a chain of etchings. I modified chain and glued into place.
I added fenders and reflective light.
Sonntag, 1. Februar 2015, 18:54
Chassis in surfacer.
I added a few elements and repaired surface.
The engine is very nicely executed. I made only minor changes.
I added the wheels, filters, and I started painting.
The rest of the parts after painting ...
Here are the last photo before the patina ...
Here are the latest photos. I finished the air valves and electrical connections. Patina is 95% completed.
Photos are not good. Weather is no longer ideal.
And here is the finished model. ;)
Czech Diesel Air Compressor DK 661
Greetings from Czech Republic.
Tony
Sonntag, 1. Februar 2015, 21:24
:love:
Unbelievable how good this model came out
I love it
Greetings from Germany Anton
Falls was net passt wirds passend gemacht. :!!
Fuktioniert etwas nicht mit gewalt nimmt man mehr gewalt.
(nicht wirklich ernst :lol: )
Realname: Marcus
Sonntag, 1. Februar 2015, 21:35
Wow!!!!
I´m speechless!!!!!
Very, very, very, very good work!!!! :respekt:
Schöne Grüße aus dem Frankenwald!!!! :wink:
Realname: Christian
Sonntag, 1. Februar 2015, 21:36
Awesome :ok: great job
Bis bald, Christian :wink:
Schöne Grüße aus dem Nördlichsten, was der Frankenwald hergibt :ok:
Meine Definition von Modellbau:
"1000 Projekte im Kopf, 100 Projekte angefangen und kein einziges fertig!"
:thumbsup:
Montag, 2. Februar 2015, 00:20
Hallo Tony. :wink:
Das ist ein sehr schönes Modell geworden. :respekt: :dafür:
Gruß Micha.
Dienstag, 3. Februar 2015, 18:09
Hi Tony,
Congratulation, precis Job. very good build.
I like it :ok:
greets, :wink:
Martin
Realname: Florian Schmidt
Dienstag, 3. Februar 2015, 23:17
Very very nice and in this Scale... :ok:
Greets Florian
Mittwoch, 4. Februar 2015, 19:12
Hello.
Thank you very much for all the positive comments. :)
Tony
Donnerstag, 5. Februar 2015, 03:48
Hallo Antonin
Ein außergewöhnliches Modell zeigst du da, das ist ja super detailiert :ok: . Ein nettes kleines Baufahrzeug :love: .
Grüße, Bernd
Sonntag, 15. Februar 2015, 18:29
Bernd :
Thank you very much. I'm pleased. ;)
Tony
